H&R Sway bars not so good!
2005 C55, 1988 260E, 2000 Chevrolet Silverado
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
If your Eibachs work well in your Porsche, I'm kinda wondering why you went with H&R in the first place. ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
I've had my Eibachs on my Benz for over 5 years now without issue. Good luck, whatever you do.
Super Moderator
Wow, sorry to hear how it all went so wrong for you with H&R. What the heck is up with that customer service & retention philosophy? You bought their parts, yet through no fault of your own, they failed. They then have the gumption to insist upon pictures and documentation from a man with a FAA Airframe and Powerplant Mechanic License?! Just ship some gratis bushings. Nobody could fault you for bolting after that kind of treatment.
I have called H&R twice...spoke with Josh Scott. When their 52732 spring installation resulted in the rear being too low, they promptly supplied a pair of 52732-2 pieces to make things right. Didn’t even want the first set returned. When their 70392-2 anti-roll bar bushings failed, apparently from lack of lubrication, they sent replacements at no charge.
When a bracket on my Hellwig GMC worktruck bar (34mm!) broke, I BS’ed with them for a minute or two, only to have them ship a complete mounting hardware kit the next day. No pics, no receipts, no drama, and no expense.
...merely sharing but two personal examples of the kind of service and support that earns loyalty in the always-competitive aftermarket parts business. Too bad it’s not universal.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
Super Moderator
Russell, did you ever get your situation squared away?
I R&R’d all four chassis bushings this afternoon to slather on another liberal application of molybdenum disulfide. It’s quiet once again, but at this rate, it’s almost as if it has become a quarterly exercise.
Still working on it. I'm thinking of trying the Energy suspension bushing with the lube fitting installed. I just had to relube the rears again. I will change those to if the fronts work out. I dont like the H&R nonlube design, they dont seem to work and I hear a lot of people with bushing failures in the front. When the bushings stay in place and its all hooked up they work great but I'm not happy with long term results. Im think I sould have just installed the AMG bars.
Super Moderator
2007 C230SS; 2014 ML350 BT
On my other cars, I run the ES greasable bushings and they work great. One rig has over 100K on the bushings and they are still in good shape. One trick I can suggest to keep the bars rotating easily and keep them quiet: Wrap the bar with a few wraps of teflon tape where it rests in the bushing.
Super Moderator
Believe it or not, it holds up pretty well. The key is to start the tape on the bar where the middle of the bushing will ride, and end in the middle. This keeps the tape from coming undone. I find the military grade teflon tape holds up longer then plain plumbers tape.
Super Moderator
They’re quite once again. Thanks for the tip.
19mm rear H&R bar installed.
Lovin' it so far.
Subtle, but not so much understeer.
Lovin' it so far.
