stock rotor size
I'm working from a failing memory, but I notice nobody else has responded. I think it's 11" front, 10" rear. I notice your sig indicates 18" wheels. I think the rotors look lost inside the 17" wheels.
Are you thinking replacement?
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
I own a coupe and I am looking for a replacement system. I just got new wheels and the design leaves the brake system wide open and easily noticable. Looks outright ugly with the stock setup. However I am trying to go a different route than Brembo because I am not looking to spend 2k+ for brakes when I would only be using them for visual apperance rather than performance. Any ideas on a company that might fit that criteria? Maybe just a replacement of the rotors(slotted/cross drilled)?
Regards,
Matt
Regards,
Matt
2002 C240 Classic
i need replacements. but not sure if you can simply swap a bigger rotor than the stock one without any modifications. anyone know if this is possible?
Location: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
1 Post
C230 Sports Coupe
Regards,
Matt
Regards,
Matt
Stock is 11.8"vented rotors in front and 11.4" in back. If you get larger rotors you need to change the calipers too, they are designed to work as a set.
