Replacing Battery
Old Oct 20, 2007 | 03:23 PM
lovetrading's Avatar
Replacing Battery
I am trying to replace the battery on my C240/01. I took the cables off, but the battery would not come out. It seems like there is something holding it at the bottom. I would be thankfull if someone can provide the steps to get the battery out.
Thank you
Old Oct 20, 2007 | 03:35 PM
Shake's Avatar
IS300
Try looking in the w203 forum
Old Oct 20, 2007 | 05:42 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
The battery is clamped down. If it wasn't, it would be flying around your engine compartment with each fast stop/turn. Look at the back side of the bottom of the battery.
Old Oct 20, 2007 | 05:46 PM
Elect. Stabil Program is not Available ESP
Ok, I was able to get the old battery out and put in the new, the car started without issue, but I am getting a message "Elect Stabil Program is not Available" Is this a reset issue? Anybody knows what is going on? Help Please!
Old Oct 20, 2007 | 06:50 PM
sludge's Avatar
2003 C230K Sedan
Check the sticky at the top of the thread list "list of faults that occur after disconnecting battery."
Old Oct 20, 2007 | 09:24 PM
Thank you so much! I followed the instruction and all is fine now. One last thing, I did not buy the new battery from the dealer, I got it from Auto Zone, and the clamp in the bottom is not securing it the same way it did with the original battery. it's somehow movable... but I do not think it will cause issues. Am I Wrong in my thought? Should I find a way to secure it?
Old Oct 20, 2007 | 10:06 PM
sludge's Avatar
2003 C230K Sedan
I replaced a battery once without the bracket because I lost one of the screws and it was fine for years (non-Benz), but I'm not sure how it would affect this car. If it feels OK, it probably is for a short time, but I would find a way to secure it. If it is movable, I think it would eventually cause stress on the terminals and wires.
Also, you should update your profile with your car type before people on this forum give you a hard time. Also a word of advice, you'll get pounded for asking questions for information that is already posted, so try the search function first.
