Help request: spark plug replacement
Old Nov 3, 2007 | 07:23 PM
sstcobra's Avatar
2002 C320 Sedan
I have a 2002 c320. Engine # 112.946.
Can someone tell me how to change the spark plugs. Specifically I need to understand about pulling the plug wires off the plugs. Do I need a special tool for this? Or do they come right off? I looked at the plug wires today and the metal cover that goes over each of the plugs. (It doesn't look like the plug wires on my '66 Mustang) Do not want to do any damage without asking for advice first.....Gary
Old Nov 3, 2007 | 08:42 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Good timing…I’m working on a DIY plug swap for the 112 V6. Bad news is it’s still not ready for uploading.
Those wires are on there tightly. MB’s procedure is to use an open-end wrench that fits in the ridge at the top of the metal connector. Use it to pry gently against the cam cover and they pop off easily.
Are you the gent who was asking about torque arm bushings? I see you’re tackling a new challenge! I’ll email you MB’s (copyrighted) plug R&R information.
Old Nov 3, 2007 | 10:24 PM
mleskovar's Avatar
'17 Jaguar XF
Be careful how you pull and replace the plug caps and you won't have problems. The driver's side plug up against the firewall is very difficult, but obviously doable. Try different combinations of sockets/extensions/handles to get the right combination that works. DON'T pull on the plug wires. The recommended tool is a 17mm crowfoot wrench but I found (through this forum) that Harbor Freight Tools sells a long reach (20") plier that is perfect for the job.
Attached Thumbnails Help request: spark plug replacement-plier.jpg
Old Nov 19, 2007 | 01:56 PM
uberwgn's Avatar
e300d
Guys, SNAP ON/Blue Point make a tool specific to this task:
http://buy1.snapon.com/catalog/item....re&dir=catalog
