MAF Sensor replacement help ! !
Old Dec 2, 2007 | 06:51 PM
jaybopeterson's Avatar
2003 c230
I know where the MAF is but can not get to the last bolt holding it to the back of the air box. Has anyone done this before? 2003 C230K
Old Dec 3, 2007 | 12:12 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
with the airbox/MAF removed from the car, I very carefully used a long allen wrench (i.e. hex) to remove it - use the biggest that will fit in the head of the bolt. You can easily strip the torx(star) socket head on the bolt if you're not careful ... In case you haven't seen it, there's a link to a thread with pic's in the DIY sticky at the top of the page. Cheers!
