HID conversion vs. Factory Bi-x???
Old May 11, 2008 | 11:47 PM
outaurleague's Avatar
w211 e500
Originally Posted by KA8
Here are some latest pix to help prove my point:
All for around $100
Tons of hot spots and angel wings, but the output is great imo. Its really all a matter of choice and money.
Old May 11, 2008 | 11:55 PM
raymond g-'s Avatar
99 E320
the moment I saw the hot spots on mine, i knew that there was no way I was
going to put up with that level of quality on my car. I drive many dark roads
here surrounding Seattle where street lights are few. i was fortunate enough
to have been able to drop in (near perfect fit) E55 bix projectors into my Depo.
the halogen projectors went into the garbage.
Old May 11, 2008 | 11:58 PM
kevblah's Avatar
E90 M3
yeah, the stock halogen housings werent built to emit hid light.
either get bi-x, or drop the hid kit into ebay projectors.
Old May 12, 2008 | 01:19 PM
dblock2151's Avatar
How hard was it to install other projectors into the DEPO lights? I have a pair of OEM X5 projectors sitting in my room and was wondering hwo hard it would be to retro-fit them in. :dunno:
Old May 12, 2008 | 02:50 PM
raymond g-'s Avatar
99 E320
I've been keeping an eye out on FS here...as well as Ebay, for a damaged
headlight off the 203....coupe and sedan. All I need is to open it up and
take measurements. With the data, I would compare against the dimensions
of all the true HID projectors out there. I'm only willing to spend about $50
to buy one for this project but so far I've not seen any FS.
All that blather just to say that at this point, I don't know. The ease in
which such an HID retrofit can be made all depends on clearances, the
critical specs of the existing mounting posts, etc. Just about any of the
HID projectors can be made to fit inside anything. It's all labor, cutting,
fiberglass, JBWeld, etc to build up areas which is needed to support
the projector, yet still provides for beam adjustment.
W210 owners are super lucky since the mounting posts are 98% the
same spacing as the E55 bixenons. Just toss in several lock washers
and you're ready to sew up again.
Old May 13, 2008 | 05:10 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i would buy the eagle eye head lights, not the depos. You have more options with the eagle eyes since the low beam part is wider. I'm retroing in tsx projectors in mine, but you can probably fit s2k's as well.
Just click on the link below if you want to check it out.
https://mbworld.org/forums/c32-amg-c55-amg-w203/242212-temjinx2-s-tsx-retrofit-project.html
