Tool required to remove the coil pack
Old Dec 16, 2007 | 01:45 PM
deltadude388's Avatar
School bus
What is that socket/tool called to remove the the 2 star like screws that hold the coil pack down? Someone mention an inverted torx socket?
thanks.
Old Dec 16, 2007 | 03:15 PM
RES's Avatar
RES
2005 C55, 1988 260E, 2000 Chevrolet Silverado
thanks.
You can get them at Sears. If your going to work on your car I would invest in both the screw driver set and the socket set. They dont cost that much there, there not Craftsman though??? In the Auto tools section at most Sears.
Old Dec 16, 2007 | 03:23 PM
rlee02135's Avatar
2004 C32 ///AMG
just a torx bit...
Old Dec 17, 2007 | 01:24 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
thanks.
Yes, inverted torx. A 6 or 7 mm socket might work, but you won't be able to get it down tight.
Sear, or even Kragen sells inverted torx bits.
I think the one for that is an E10 or 12...I ferget.
Just buy a set if you plan on keeping the car.
15-30 dollars...
http://www.etoolcart.com/browseprodu...-LIS26750.html
