Sunroof Moving in 1inch Increments...
1 Post
02 C320 S.E., 02 BMW 330XI, 00 4Runner
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I been using my sunroof even in the colder weather. I went to open the sunroof yesterday, and it won't go back in one fluid motion. It goes back in 1 inch increments at the moment. As far I as know, I haven't done anything that should have caused this.
Does anyone have any great ideas?
Thanks,
Adam
Thanks,
Adam
Hi
You need to reset your sunroof
Push it to tilt upwards and keep the switch pushed up for 1-2secs
That will reset it.... I think that was the way.
If it doesn't work, it's in the manual......
Cheers
Cheers
this happens to me.....and it was on a DAMM HOT DAY...i couldnt even close the shades..but after a fredays...it work fine again...
at least i learnt a lesson..NEVER open your shades on sunny days....just in case it doesnt close
Also..my windows went crazy yesterday..when i try to close it (the pax side)...it went up..and then went down 2 inches!....after a while..it return to normal..
2001 Silver C320
its a service issue. you need a new control unit. i have a 2001 and just had to have all that replaced. call your dealer. the reset thing where you hold it up for hree seconds to re-sync it is just a temp fix, it will screw up again when you turn the car off.
2010 C300 4matic
