to the experts in lighting
will the bulbs and ballast that are from a a set of factory xenons fit in the housing of my stock halogen?
or do i have to use the xenon housing?
are they the same housing?
if somehow it works , will it melt the stock halogen housing?
xenon housing is cracked, but xenon bulb and ballast are still good. wanting to put them in stock halogen housing.
thanks in advance.
Many of us have the aftermarket kits and they are identical to benz except for the bulb mounts.
Peet
but wait... if its an h7 (hid)bulb than shouldn't mount the same as a regular bulb (halogen)?
if i have all the wires to the bulbs and ballast, don't i just replace the halogen wiring or is that impossible?
i dunno cuz i have never seen the factory xenon.
The stock one supplies standard 12v to the ballast - wheras it used to come to the bulb. Original draw 55W new draw ~30W... so in effect you're reducing the amperage across the supply wire.
As far as beam pattern, I too was worried about it - but said the hell with it and went for it. Guess what? the beam pattern with xenons in the halogen housings is almost as good as that which was on my factory xenons on my former BMW.
Nice clean cutoff, larger right flood and higher level to light up the right side of the road - in other words - perfect. As far as backscatter I don' think there's much because I never get flashed from oncoming drivers.
P
The wiring harness will be just fine - because the wire feeding the bulb from the ballast is included with the ballast or bulb - NOT the one that is stock.
P
you are right about the lower amperage. however, when the xenons are ignited, it requires double the amount of power used to ignite halogens. that is why there is the need of the harness.
No. The only wire that sees that increased power is the one from the ballast/igniter to the bulb. The stock harness will not experience it.
And yes that voltage boost only occurs between igniter/ballast and bulb. The voltage increase is handled through capacitors and circuitry internal to the ballast - no additional voltage is seen in the feed wire.
it seems the factory xenon housing has been damaged an dth guy want to sell me everything else.
what is the difference if they are both h7? doesn't that mean they are same size and make, meaning they should mount the same.
sorry, no idea.
