oil capacity in 2002 C230K?
I've searched and read the handbook and checked other forums and websites and found varying numbers for this information. I drained the oil via the drain plug and left the plug out and the filter housing loose for 4 hr before removing the filter. I measured the oil I drained out and it was a little bit over 7 qts. The computer shows full as does the dipstick. I'm not too concerned, just curious as to the different volumes removed.
1 Post
2005 smart cabrio; 2008 Mercedes-Benz B 200
research?
Originally posted by BrabusCClass
From all the research I did the C230K hold just a bit under 8 quarts.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
M111 oil capacity is 7.0 Litres, or about 7.4 US quarts, including oil filter.
