Wheel Torque
Old Nov 21, 2002 | 11:26 PM
hope's Avatar
1998 ML 320, 2001 C 240, 2002 CLK 320
Wheel Torque
What is the correct wheel torque for my 01 C240 with aftermarket wheels?
Old Nov 22, 2002 | 12:11 AM
peet's Avatar
09 C63
RTFM (it's even in the index)
But, I set my C230K to 85 (manual states a tad less though).
Old Nov 22, 2002 | 09:44 AM
jrct9454's Avatar
'14 GLK250 Diesel
Yes...
Page 335 of the '02 Manual [look for the section on changing wheels/tires] clearly states 80 ft/lbs.
Varying up a few pounds is not going to be harmful, but making all five bolts even is critical. Uneven torquing is the chief cause of warped rotors, as you probably already know. I would never go any higher than the 85 ft/lbs in the post above, either, for the same reason.
Old Nov 22, 2002 | 10:26 AM
peet's Avatar
09 C63
Let me throw on a reason for the even torque..
I've had to replace my hub and rotors because of lazy tightening process. Now - by hand, then torque wrench.
Until you've replaced a hub - you haven't lived! 2 and 3/4" socket!! air hammer. Not to mention the expense. If dealer was to do it it would have been $800 - plus rotors.
Youwch!
Old Nov 22, 2002 | 11:49 AM
jlm's Avatar
jlm
I think hope's request was intended to ask if the recommended torque setting would be different for aftermarket wheels. Froman engineering perspective, I can see how that might be the case, but I have no idea if it might be correct. Anybody have experience in being told to use a DIFFERENT torque setting for NON-STANDARD wheels?
jlm
Old Nov 22, 2002 | 01:27 PM
NANA's Avatar
C230K Manny, Albaster White/Oyster Leather/C1/C5/C7/CD
If the manual is wrong, why do you RTFM?
Old Nov 22, 2002 | 06:53 PM
Matt230K's Avatar
2010 C300 4matic
hope, what exactly makes your car a C240 AMG? wishful thinking?
