2003 c240 Brake job $450 front
Old 02-20-2008, 05:39 PM
joddo's Avatar
2003 C240
is that a good price? over $800 for front and rear they claim to USE OEM rotors and pads
Pads/Rotors sensors
if not any one have a good online parts supplier
Old 02-20-2008, 06:34 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
dealer quoted u 800?
way over-priced...
Old 02-20-2008, 07:22 PM
exanimas's Avatar
2005 A4 1.8TQ
I was quoted like $400 at my dealer for the rears... eff that man. I'll go somewhere else and get the pads/rotors i want.
Old 02-20-2008, 07:53 PM
bumpnzx3's Avatar
W203 C230SS
if you've got simple hand tools and a jack, it's easy to do yourself. you actually don't even have to have a jack- you can use the cheapo one that's in the trunk.
Old 02-20-2008, 08:32 PM
moc320's Avatar
2002 Mercedes C320 Sport Sedan, Lexus Rx300, Dodge 2500 Cummins
front and rears were done on my car (pads rotors sensors) w all oem mercedes parts for 550...w/ warr
Old 02-21-2008, 11:12 AM
joddo's Avatar
2003 C240
Thanks for the info I have ordered
Parts Ordered
2001 - 2005 Mercedes Benz C240 Pagid Brake Pad Set Brake Pad Set Price: $72.95 Qty: 1 Part #: W0133-1612179
2001 - 2005 Mercedes Benz C240 Pex Brake Pad Sensor Brake Pad Sensor Price: $6.95 Qty: 1 Part #: W0133-1639613
from
autopartswarehouse.com
The parts person said they are OEM for my make and model I hope they dont dust up as much as what crap is on their now. I am not the orig owner so I am not sure what is currently on the car. I will update the thread when I complete the job
total price was 79.90 including shipping!
Old 03-17-2008, 11:52 AM
joddo's Avatar
2003 C240
Brake job complete
All,
Now that was an easy brake job the pads fit perfectly and the whole process took about an hour
Tools needed
18MM socket, Pry bar, Jack, lug wrench, a can of brake clean and brake pad backing grease
Here are the steps I performed
Jacked up vehicle (use jack point on frame)
Pop hood and loosen Brake fluid reservoir cap
Remove tire
Use pry bar to compress brake caliper
Remove two 18MM bolts on back of caliper
Remove caliper, Brake pads and pad guide
Unplug brake warning sensor from right side pad set
Install new sensor in inside pad install new pad guides in caliper
Lube back of brake pads with backing grease
clean rotor asembly with brake clean
Pop new pads in to slide guide and install caliper
Repeat process for other side
Install tires
And don’t forget to put the brake fluid reservoir cap back on
The only hard part was the brake lines don’t have much slack so the caliper is a little hard to maneuver
Save approximately $400
Highly recommend doing this yourself
Old 03-17-2008, 12:21 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Generally you don't need to undo the bolts on the caliper unless you were replacing the rotors, at least on most cars.
But good job on the DIY, such an easy a job a caveman could do it.
Pagid's aren't bad, about like stock as far as softness, and dust.
You'll get between 20K-40K out of them.
Ceramics are far superior for just a little more, last much longer and don't dust. Next time do a set of those and new rotors,and you won't have to touch it for years to come.
In the future, I wouldn't recommend autopartswarehouse.com.
You got lucky.
They have a very bad reputation.
But overall, it's refreshing to hear a happy ending to a heading like this.
I'd love to be able to just pay the mechanic, but paying myself $200 an hour instead of him is just too hard to pass up.
Quick Reply: 2003 c240 Brake job $450 front
