alignment needed??????
Old Nov 26, 2002 | 01:25 PM
LorinserCClass's Avatar
The True OG Modded out W203
I just installed a set of 18x8.5/18x9.5 chrome 3 piece wheels and dropped the car with H&R springs( I also couldn't resist I got PIAA extreme bulbs-BTW very freakin expensive 120 a set!-for my fogs and my headlight-clean look though-and I got chrome muffler tips, debadged the car-gives it a clean look- and ordered the lorinser lip kit-it is going to take 2 WEEKS they are stuck at the ports!?!) So to my question-enough rambling but i'm excited-
when should i do my alignment and do you guys recommend anyone in the san fernando valley? Any help is greatly appreciated.
Old Nov 26, 2002 | 01:30 PM
antonio's Avatar
2002 C240 Classic
you should have done an alignment when you got the springs installed. if you didn't, i would do it right away.
Old Nov 26, 2002 | 01:35 PM
I read in one of the threads that they recommend the springs to settle? So that is why I haven't done it...so on average how much should it be?
Old Nov 26, 2002 | 01:41 PM
KWiK's Avatar
2002 C230 : 2007 C230
yes, you now need to get an alignment. If nothing else, it will get toe back where it should be.
antonio's Avatar
2002 C240 Classic
okay i understand. i assumed you bought a new set of shocks also. i guess thats not the case. regardless, you will need new shocks in a year's time beacuse the lowering springs will decrease the shocks compression and give them a very short life. in any case, you shocks should settle in about 2 months time.
Old Nov 26, 2002 | 03:10 PM
mdp c230k's Avatar
2002 c230k
Wait at least a month before getting the alignment done. Take a look and see that the camber isn't too far off and you won't have a problem waiting.
Old Nov 26, 2002 | 04:29 PM
KWiK's Avatar
No need to wait a month, all major spring manufacturers pre-stress the springs nowadays. You won't see any significant sag after a month.
Old Nov 26, 2002 | 04:49 PM
Franco's Avatar
2002 C32
I agree with KWiK. I had H&R Sport Springs installed on my C240 and had my alignment done right away. I have not noticed any additional drop since the springs were installed.
Old Nov 26, 2002 | 10:34 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
I disagree. I've had the the same springs for a year...the right side sagged an addtional 1/4" and the left a little more than that. In order to correct it, I had to go the the local parts store and buy rubber "helper" inserts to correct it. It's one of the reasons why I'm switching back to Eibachs {Carlsson}. I've owned 3 sets of them with no problems.
Old Nov 27, 2002 | 09:27 AM
Franco's Avatar
2002 C32
CHATMANR,
Sorry to hear you are having problems with your springs. I have only had mine for about three months now and so far so good but I will pay closer attention to them given your experience.
Old Nov 27, 2002 | 03:06 PM
CarlssonPower's Avatar
2002 C240
There is a note in the H&R cup kit package says that you must do alignment whenever you raise or lower the vehicle ride height.
How about changing wheels... is alignment needed after changing wheels??
Old Nov 27, 2002 | 03:16 PM
Lynn's Avatar
No alignment is needed when changing wheels. Changing wheels does not affect the steering geometry.
Old Nov 27, 2002 | 03:29 PM
2002 C240
Thanks for the info.. ok I will do my alignment first while I am still waiting for my wheels to be delivered.
