OBD-II reader issues
Old Mar 21, 2008 | 01:17 PM
Kristen's Avatar
C-class
I have tried 2 OBD-II readers for a laptop and cannot get either to connect. Has anyone had success getting an OBD-II reader connected to their cars?
Old Mar 21, 2008 | 06:21 PM
06c230hwd's Avatar
06' C230SS
you arent going to get to many responses with such a vague post! so let me help you out here. brand, model, of OBD-II reader? i'm sure it's just your software is out of date. but with more information, it'll be easier to determine maybe you THINK it's a OBD-II scanner Anywhoooo- update your software and VOILA
Old Mar 21, 2008 | 07:11 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Where are you trying to connect the reader to?
Old Mar 21, 2008 | 09:17 PM
Kristen's Avatar
C-class
OK here are details:
Auto Enginuity (www.autoenginuity.com/) OBD-II reader and supplied software
- cannot detect protocol
- used about a year ago and worked fine, prior to "oil in engine harness" issue
OBD Pros (www.obdpros.com) OBD-II reader and supplied software
- forced into ISO mode, cannot connect
I have a 2003 C230.
- It uses an ISO connection
- Dealer has been able to read codes since "oil in engine harness" issue
- Dealer uses Star Diagnostic, which connects via the OBD-II port
- I have the schematic for the OBD-II port for a 2003 C230, the only connection is the ISO connection to the ECU, pin 7
- Thus if the dealer uses the OBD-II port successfully, an OBD-II reader should be able to as well
So I cannot explain why 2 different OBD-II readers cannot detect the protocol or connect to the car, yet Star Diagnostics still works.
I'm blaming the "oil in engine harness" issue on this, stupid MB reliability.
Old Mar 22, 2008 | 12:57 AM
Buellwinkle's Avatar
I use software from http://www.obd-2.com/, Alex Peper. Has worked for me for years on all types of cars including our SLK230 and C230K. The software looks a little primative but that's on purpose so it can run on any old laptop.
Update your profile with location so maybe someone in your area can let you borrow their reader to compare.
Old Mar 22, 2008 | 08:47 AM
zedhead's Avatar
1993 F250 TurboDiesel
I'll second the Alex Pepper OBDII reader. I've never had a problem reading codes with it. On virtually all brands of vehicles. I run it on an old IBM B&W laptop, that I paid $25.00 for.
