BIX upgrade questions
1.) Who has them on their cars or has in the past???
No!
2.) What do you have to say about them? Feelings/Concerns/Pros/Cons???
Depo = Low Beam Only. Depo = Lower Quality Beam Pattern. Other than that, they are awesome replicas. OEM Bi-X = Low & High Beam. OEM Bi-X = Perfect Beam Pattern. So it's safe to say Depo < OEM Bi-X for two good reasons!
3.) Most kits...Do they come fully equiped with everything you need to have for bolt on and use???
MTEC SLIM HID KITS
4.) Is there any extra items you need for the application?
No and you really don't even need the porjector lamps you could just use your Halogen housings, but then again I think the best part of Projector lenses are the look in the daylight.
5.) Last Q...Where is the best place to purchase and what is the typical price???
MTEC on eBay is about $240-$340
Thank You for any help in advance...and for the guys who a 100% about the OEM...I understand and WILL have them this year...hahah just want to try to cheap ones for a bit
I don't blame you. I still havent splurged for the OEM Bi-X yet either.. but I'm willing to wait until the summer rather than buying Depo's now!
I honestly don't think the beam pattern and hot spots will bother me so I think I'll be OK.
Thanks to all that replied and helped answer all my questions.
I read through a ton of posts about this light issue before i did what i did.
I'm very satisfied with the outcome of my install and do not have a light pattern issue, nor do my lights give off unpleasant glare, i did check out all concernes mentioned after my install.
I had planned to buy Depo projectores as well, but decided against it after doing my research here on this forum.
Good luck with whatever you do deceid to do.
T.
Again, thanks for all the help.
Thanks.
I bought them over the phone and should have them within the week!!
Now to find a place to program xenon=present
Bixenon's definitely a good investment.
Thanks, but it would be a little late now I suppose.
Flippin dealers are killin me with prices. I called another dealer (Wagner) and asked about the service A and was quoted $250. A little less than the other MB dealer but still over priced. I then asked about the program for xenon=present and the woman had no idea and said... "well, I'd assume at least an hour, so $115". I've started a search for a local independent repair shop with MB experience but thus far have come up short. I suppose I could call back and see if she meant a minimum of 1 hour charge or if it would a fraction of an hour if that's all it took.
I'll continue to look and ask around but fear I'll have to be over charged for the xenon=present.
Do I have to wait until I install the BIX to have the xenon=present set or can I have it done THEN install? Meaning, if I went to the dealer on Friday afternoon and had it set, could I then install the lights Saturday or even Sunday?
Thus far with the few calls I've made to local shops, not one said they can set the xenon=present and every one of them suggested the dealer. I'll probably bite the bullet and pay their inflated fees.
Steve and Wanda are amazing, and anyone wanting Bi-x should go with them. Yes $1300 may seem steep, but you are getting brand new MB parts, so definitely worth the investment. Put it this way, it's like a $1000+ option when you used to upgrade the car with Bi-x when buying from the dealer.
I found installation to be tricky, as no stealer wanted to do it. I took it to a highly recommended shop in the Toronto area, but they didn't have MB Star diagnosis so I had to pay the stealer to change the computer.
If you install them and then code it, your lights will mainly not work, or flicker. It doesn't do any damage, just you can't really drive at night.
"Do you have the Star Diagnosis computer for mercedes?"
Asking if they can code Bix is like shining a spotlight on a deer on a dark night...
Once you've determined they have the computer, ask whats their hourly rate is..hopefully it's close, drive there with your bix in hand (or rather, trunk) Show them the lights, explain what you're doing and hand them the coding sequence from this website, and ask how much? Hopefully a 50 dollar bill in cash will be enough. Cash is good.
Asking if they can code Bix, they probably won't say yes, if they've never done it before.
An yeh, get it coded in advance.
I tried to get my local guy to do it, but he went,
uh...whats this? I told him. And he was like, "that doesn't sound safe" and refused, though I was paying him to connect the computer, but for other reasons (clearing SRS errors) . But then I don't have Bix...just figured I'd get it set since it doesn't seem to have a bad effect if you don't have them, and if I got them later, I'd be ready to go.
I actually stopped by one of the local independent shops to speak to one of the tech's and I started talking about the star dignosis. He started to explain they recently upgraded their scan system and specifically added the MB and BMW software. I'm not sure what that means but I did mention the pics and detailed instructions (thanks for that tip as well and kudos to JohnCL for posting that
Wish me luck and a huge thank you to all that helped with my questions.
We'll see how long these last...
Too bad I don't have a sedan...
complete set of Bix for...
$275 including shipping, but something about a cracked housing?
How bad can it be? A little glue maybe?
http://cgi.ebay.com/ebaymotors/OEM-W...ayphotohosting
I wouldn't based on his description
"...on a pair of Mercedes-Benz Genuine C Class W203 Bi-Xenon Headlamps.
This is an OEM version from Mercedes..."
Sounds like collision damage...
I wonder...is there any way to disassemble them, and put the inards into the coupe stock headlight housing?
Hmmmmm.....
Well, doesn't matter....they're sold.
Lasted about an hour....
