off centered steering wheel
Old Jan 12, 2002 | 12:05 PM
BruNo's Avatar
07' ML350
Hi
my c240s steering wheel is slightly off centered, its like 12:03, 3 minutes past twelve. wheel alignment is perfect though, the car goes straight, tire pressure is also correct. I just wanna know on how to center the wheel without having to remove it, and moving it one or more teeth over the steering column spline. Ive heard that toyotas n honda's wheels can be finely adjusted thru their steering racks....
btw, could centering the wheel affect ESP in any way, causing faults to appear in the process???? thanks!
Old Jan 12, 2002 | 12:45 PM
mleskovar's Avatar
'17 Jaguar XF
I had the same problem. You don't adjust it at the steering wheel, but at the rack. Common complaint. After the service they included a computer printout of where all the wheels were adjusted within the tolerance limits. I thought the alignment was fine before I took the car in but after the alignment it tracked noticeably better.
