Seafoam on C230?
What where the results? Was it worth it? I plan on doing an oil change soon, so I was thinking about giving it a try. Oh, and btw my M111 has 117,000KM on it.
E
You don't want it in your gas tank either. If you are using top tier premium fuel, you have all the gasoline additives you need in your tank. Adding non-detergent oil can put carbon in your combustion chamber because it does not burn well. It can fool the motor electronics into less than optimum operation, and muck up or ruin your oxygen sensors. It is not a good idea to run oil through the cat either.
The best place for almost all engine and gas additives is on the shelf at the store.
There is one you might need if you are in need of injector cleaning or carbon removal (mostly on 4 cyl supercharged cars.) It is Techron from Chevron-Texaco. It is the only additive approved by Mercedes.
I personally will use alcohol or kerosene to clean a crankcase, with the pan off, if some knucklehead put conventional motor oil in an engine.
I suggest you save your money and go see a movie instead!
Yeah, it's probably best not to use a product like these. Mercedes does not recommend it.
Always have your oil changes done with proper synthetic oil, and you should be set. No worries.
