help with spring install needed!!!!
i just finished doing the front left corner install on a used set of lowering springs i picked up dirt cheap. i just reviewed the video how to posted here on the boards, and i did everything that the video showed. only problem is the car sits exactly as before!!!!!!!!!!
i double checked to see that the top hat was seated properly...
everything went back together exactly as it came apart..
anyone explain????!!!! i have been beatin my head against the wall all night..
do i need different spring pads? shouldn't i expect more than a 1/4"?
just to make sure i didn't get duped, i took my factory spring and cut a coil and a half off it, put it back in, and the same thing!!!!!
i am very experienced in lowering vehicles...hell, i body-dropped my last mini truck myself with some guidance from an airbag shop....but this one has me stumped...
HELP ME PLEASE!!!!
HELP ME PLEASE!!!!
I installed the AMG C32 springs/shocks on my C230 and the drop was exactly the same as stock, but the ride was much firmer and cornering was much improved.
my top hats weren't seated right in the front shock towers, even under the weight of the car, it wasn't dropping enough...
i solved the front, gettin ready to tackle the back tonight..
will be postin pics up sometime this weekend...
again, thanks for the help, guys....
