19" rim
Old May 10, 2008 | 04:28 PM
fatkei's Avatar
c230
19" rim
Hi, my car is 2007 c230 with sport pck.
I am thinking if I can get a set of new rims.
The front 2 rims are 19"x8.5"
The rear 2 rims are 19"x10"
Hub Centric 66.6
Offset 40 / 45
Can someone tell me if it is possible or not?
Old May 10, 2008 | 05:45 PM
e1000's Avatar
a quarter mile at a time
offsets are wrong, you'll need spacers. Rear is a bit on the wide side, might rub if you run 265's. Make sure the bolt pattern is 5x112 as well. Even after all of this, not all wheels will clear the front brake calipers.
Old May 11, 2008 | 01:29 PM
RDSBENZ's Avatar
C300. FJ Cruiser, 370Z
You need a 5mm spacer in the front and 10mm spacer in the rears.
