Went to check cam sensor for oil...
Old May 12, 2008 | 12:54 PM
DiBenz's Avatar
19 XC90
I popped my hood to see what it would entail to get at the cam sensors to inspect them for an oil leak. I got a message on my dash to add a quart of oil so I did a search here at the forum and found the cam sensor threads. I need to get some reverse torx tools, but in the meantime I peaked under the plastic a bit and found this...
Looks like the hose connector there in the middle is cracked at the top. And...
Clearly there is oil on the bolt there to the right and some oil around the area. Just wondering if you guys could shed any light on my current findings?
Old May 12, 2008 | 01:01 PM
Kristen's Avatar
C-class
That hose is coolant, not oil.
The oil you're seeing most likely leaked from the cam sensors right above it.
Old May 12, 2008 | 01:06 PM
DiBenz's Avatar
19 XC90
Yeah, I figured that wasn't oil related, but I would throw that concern in there while we were on the area. Thanks for the reply. I don't see oil coming from the cam sensor area down to that bolt though, seems like its just coming from something near the bolt. I will take more pictures when I get the plastic off the top and check the cam sensors more thoroughly.
Old May 12, 2008 | 01:09 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I find that in general, 4 bangers tend to vibrate themselve loose a bit.
Maybe, clean up that bolt a little, check it to see if it's tight, and then keep an eye on it. Maybe a drop spilled when the oil got changed?
I get some leakage around the valve cover, torqued 'em down a bit, and it stopped, and at one point the nuts on the exhaust manifold kept coming loose, and spewing exhaust fumes into the cab when the ventilation was on. Just tightened them up, problem solved.
Hopefully it's just a loose bolt.
Old May 12, 2008 | 01:15 PM
Kristen's Avatar
C-class
The cam sensors leak through the connector, not around the sensor. So oil will drip from the connector and splatter on anything nearby, or if you're lucky, hit the belt and splatter everywhere!
