Custom "FULL" Upper Switch Row
http://www.honeysw.com/canproject.php
Thanks,
Jake
I contacted Volico and they were very happy to be able to supply me with a new paint which should be a more saturated black and have more sheen. I hope that it matches the OEM color and finish of the buttons. I will paint the button covers soon, but in preparation, I made new icons for ALL the button covers that DO NOT have a slick co-molded clear lens for the RED LED indicator…
Here they are…I will update with painted parts then etched parts soon…
Any and all comments welcomed!
Thanks,
Jake
Thanks,
Jake
jake,
do you think a LABEL PRINT Shop will be able to create thsi icons as transparent stickers? not sure but they are nice. keep us posted
You need to REMOVE material overcoat to get the button to be back lit...I don't think that a label is the correct answer for this one...It could be okay during the day - but it will NOT look OEM - It has to be laser etched...
I messed around with a few different paints, a NEW Volico Paint (which is VERY close - it does not have [or I can not achieve] the proper satin finish...it seems that the TESTORS satin finish overcoat is the best for matching sheen - Now I need to find a finish that is AUTO grade!
Thanks all,
Jake
Thanks all,
Jake
Cintoman
dbvolz - Thank you - That seems to be the way I will do this...Over Coat ALL the buttons uniformly with the Satin Finish I find and choose to use - I am NOT going to use TESTOR'S as it IS NOT automotive grade and I will not trust it to the extremes and use that these parts will have to deal with. I am looking for a good finish. This Testor's Satin Finish is over the VOLICO.de Black Interior paint...That is the quality base.
Cintoman - Thank you - The Testor's as mentioned above is an overcoat of the Volico.de paint - which is very very close...I think spraying the entire switch row set of buttons with the same finish - is the ONLY answer I may have...
I have thought about trying to contact tier 1 OEM suppliers here State side to see if I could pick up some paint - But we all know it will be different between a GM, FORD and a Mercedes-Benz...Chrysler product might be closest...
Thanks,
Jake
Think "Distronic" icon...
Opinions and comments welcome,
Thanks,
Jake
So here is my FINAL...Actual parts should be soon...
Thank all!
Jake
Edit: Have you figured out how to tap into the computer or the unused switches?
For example, I like the 110V outlet icon, but obviously, you can't flip this button up to reveal an outlet. So do you have a plan on where to install this outlet?
I also noticed that you changed the look of some of the already-existing icons (eg: the rear sunshade, and the lock/unlock padlocks). Any reason for this, or you just didn't like what they used for OEM?
I'm very detail-oriented, so I definitely appreciate all the dedication, thought, and efforts into this. I definitely
to all your efforts. Looks awesome Jake !!Cintoman
Jake
(I will answer the other posts later...THANK YOU!)
As far as the 110v outlet - think Chrysler product...it would be for the REAR passengers...big plan (LONG TERM) I don't want to get rid of this car (I have had my w123 for 14 years) is to create a rear console...
Jake
hahaha j/k
http://en.wikiquote.org/wiki/Triumph...sult_Comic_Dog
Jake
Jake
that is nice and the recycle icon sweet didnt thought of that! damn you got skills Jake this thread is getting more and more interesting. im going to bring your icon layouts to a vinyl and sticker shop and try to ask them if they can make some sort of transparent sticker.
1.) First "Final" etchings were set too hot - BURNED white plastic, etched too deep and yellowed the plastic...
2.) Second set showed that the first set had BAD DXF files...very rough and bad edges...
3.) Had to learn new program to create clean cutter lines...
4.) Had to find BLACK primer to resurface the OEM buttons to try again...
Made new art - That I hope will etch...and I am headed to the shop to sand and surface the bad OEM buttons...
That is where I am now...Dang thing is turning into a THESIS!
Jake
Well, I have not yet made them work...The PCB is there, as soon as I have a working "prototype" in which I mean MY ART Work on moving buttons...I will be able to take it to get scoped for the CAN signals....Then starts PHASE TWO.
I decided to go FULL GAMBIT...I am not happy that my paints are not matching 110% to the OEM finish, so what do you do...You make them all!
Stay tuned...But here is the OEM Heated Seat and Tow / Alarm button covers...WOW! Well done! Two runners per color, plus the clear parts!
Here is my final full row art,
Jake
