How do you replace the bulb for the light inside the trunk
Old May 13, 2008 | 07:44 PM
naijabenz's Avatar
2005 C230 (W203)
I have searched far and wide for instructions on doing this but the closest i got was instructions to replace the license plate bulbs.
On one of the on-line forums, someone suggested using a flathead screwdriver to pry the whole assembly off. I tried doing this from the left and right side of the assembly but it just seemed to come out only slightly out of the enclosure. Worst off, the housing now became loose and rattled around after doing this which meant that I was doing it wrong. Any help will be appreciated.
FYI: This is on a 2005 w203. Thanks.
Old May 13, 2008 | 09:35 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
No, those directions are correct for a pre-facelift. For 2005+ it *could* be different. And I dunno about yours, but the clear piece has always been loose,
Old May 13, 2008 | 10:04 PM
LuxuryC240's Avatar
2003 C240
I have a pre-facelift and I've tried to change this bulb, and never have been able to get the lens off. It doesn't work anymore because I was trying to pry it out...so who knows?
Old May 13, 2008 | 10:24 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
I've been looking for a way to change those lights for so long, too.
Old Mar 20, 2010 | 11:57 PM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Bring this old thread up. I tried to remove the len by pushing it from left to right and it tilted a little bit down but still cannot remove the housing. My fingers are hurt.
What is the best way to take off the len? What is the length of that festoon bulb?
Anyone knows?
Thanks.
