Sirius Radio Options other than dealer?
Old May 18, 2008 | 09:44 PM
gknight8's Avatar
'07 C230 - '08 SLK350
I have a '07 C230 with the sirius ready head, is there any other way of integrating the head unit anything other than with the factory sirius unit? And if you did it what unit did you get? Thanks
Old May 19, 2008 | 03:44 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Perhaps buying the require parts at a wholesale dealer (trademotion mercedes) and then buying the maintenance DVD from mbusa. Then you can install the sirius yourself and save money.
Old May 19, 2008 | 06:07 PM
ChrisBrown's Avatar
2005 C240 4MATIC, 2020 GLC300 4MATIC
You could get an aftermarket Sirius radio and use the Aux-in to feed the audio. But if you want integrated with the headunit, then you have to use the Mercedes parts. You might find them for a cheaper price on eBay, just be careful who you are buying from.
Old May 23, 2008 | 02:26 PM
blown93lx's Avatar
2007 C350 6M
I had SUNIL integrate my SIRIUS into the COMAND. It's absolutely worth the money. Having the best work on your car is expensive though!
Old May 23, 2008 | 05:51 PM
ChrisBrown's Avatar
Did you use the Mercedes modules? Or did you use an aftermarket external Sirius radio and use the aux in?
Old May 23, 2008 | 05:56 PM
blown93lx's Avatar
2007 C350 6M
No mine is completely integrated. Nothing using an AUX port. Mine uses the factory OEM Mercedes Sirius module. Also had a painted sirius antenna mounted on the trunk. Looks awesome
