Puddle light wiring question
Old Jul 12, 2008 | 04:00 AM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
I searched but couldnt find anything..
so here is my noob question
Is there a wire that I can attach the puddle lights to that does these-->
1. When the door opens the light goes on
2. The lights shut 15 secs (or whatever the time the setting is) after the door is shut
3. When you turn on the interior dome light manually, the puddle lights will not go on
Old Jul 12, 2008 | 04:49 AM
Mu9enx's Avatar
01' C32o
hmm, it seems that most people use the interior dome light, so number 3 would be hard to do. i personally used the rear dome light, so that it lights up when the car is unlocked and locked. and then you would be able to use the dome light without turning hte puddle lights on.
Old Jul 12, 2008 | 12:26 PM
RW C55's Avatar
But with this setup, would the puddle lights be turned on when only the front doors are opened? I know that the rear dome light won't light up in that case.
Old Jul 13, 2008 | 02:42 AM
JERU107's Avatar
2002 Mercedes-Benz C240 sedan
It will light up if you have the dome light set to come on when the door is open. I used the Mercedes retrofit instructions and it said to connect to the rear dome light. Turns on when you unlock with the remote, when you open the doors (dome light has to be set to come on with the doors) and when you turn on the rear dome light. It also fades out after you close the door.
