5min engine "looks" mod
Old Dec 20, 2002 | 01:41 PM
speedfrk's Avatar
C230 coupe 6sp
Decided to do my first mod (except stereo). Took about 5 min with a DA (220 grit paper). Just sand the paint off the top of the lettering, and it will be a machined alum finish when you are done. You can probably use a drill and sanding disc to do this if you don't have a DA. Just use 220 or finer paper. Keep the disc almost flat on the lettering to avoid hitting the paint on the other part of the cover.
Old Dec 20, 2002 | 01:42 PM
BrabusCClass's Avatar
GL450, Sienna SE
Looks Good!
speedfrk's Avatar
C230 coupe 6sp
another pic
Old Dec 20, 2002 | 01:45 PM
KWiK's Avatar
2002 C230 : 2007 C230
Nice job
Old Dec 20, 2002 | 01:49 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
Very nice!!!
Old Dec 20, 2002 | 01:52 PM
CANTOEVO's Avatar
Porsche Cayenne Turbo, 360 C.S.
looks good, but would it rust now that's clean metal???
Old Dec 20, 2002 | 01:54 PM
speedfrk's Avatar
C230 coupe 6sp
BTW, you can also do this by hand with a sanding block, but it will take quite a bit longer. Also, it you are worried about hitting the rest of the cover with the sandpaper, just put duct tape over it first.
Old Dec 20, 2002 | 01:59 PM
speedfrk's Avatar
C230 coupe 6sp
It's aluminum, so it may darken a little, but then you can just go over it lightly again every 6 mo or so. Ot you can brush a light coat of clear over the top of the letters. If I had a car with a distinctive color, like the blue or green, it might look good to paint the entire cover that color, then sand the letters and then clear coat the whole thing. My car is white, so it would not look good, but some other colors would.
Old Dec 20, 2002 | 02:15 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Just keep in mind that the clear coat must be heat resistant - otherwise it will get burnt fairly quickly.
