Noise from rear hatch of C320 Wagon
2002 C320 Sport Wagon
I have not yet resorted to riding in the rear compartment but I suspect that my rear door may be the source of soft crunching noises that I hear on turns and bumps at speed. Has anyone similar experience? Is there an adjustment or repair?
Kal
Kal
1 Post
'02 C320 Wagon
I've not heard anything like what I'd describe as a "crunching" noise, but the rear cargo compartment does have it's share of rattles/cluncks from the assorted panels. If we take a vacation and have the rear packed reasonably well, voila - no more noise.
Try removing the two side panels and the floor cover and tray, and then hit your favorite section of bumpy road. If the rattle goes away, you've found your source; if not, you've just narrowed it down some more.
FWIW, the two adjustable door stops on either side of my rear hatch were installed backwards, so the rear door was making more noise than it should. Installing and adjusting them correctly helped quite a bit. Some silicone-based grease on the rubber stops helped out as well.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Just a suggestion...
Thanks.
Kal
1 Post
'02 C320 Wagon
If you have the Benz Service DVD, do some searching and see if there are any service campaigns listed for this issue - sometime the factory will already have put together a kit just for the purpose you need.
I'd start by adding some sort of felt strip around the outside of the cover and/or tray, where they sit in the tire well. This ought to help dampen any noise and movement from them.
Kal
