Grill Chrome Strps Question
Old Jul 30, 2008 | 03:17 AM
kiamcoj's Avatar
2012 CLS63
Has anyone tried removing the chrome strips from the front grill? If so do you have any tips on the easiest way to get them off? Thanks.
Old Jul 30, 2008 | 10:29 AM
Mu9enx's Avatar
01' C32o
hey jon,
are you talking about the oem grille or the CL grille? the oem grille is 2 pieces, one being the silver chrome/aluminum face and the plastic back piece that is black. you just pop tabs; they are located all around the back of the grille. you also have to pop it out from the slats; there are a lot of em'!
Old Jul 30, 2008 | 05:32 PM
kiamcoj's Avatar
2012 CLS63
Thanks Tommy...
I see the tabs but they're a ***** to push down on. Any tips on how to push them down?
Old Aug 1, 2008 | 02:57 PM
tudu's Avatar
Mercedes Benz C200K Sport Edition and 04 C55 AMG
Thanks Tommy...
Use a small screwdriver and a bit of paitence as the tabs are easy to break if you try to force them. Once you get the first one off the rest should follow easy.
Old Aug 1, 2008 | 04:35 PM
BF_JC230's Avatar
2005 w203 C230
Yeah - It is not that hard - use some soft tools that are non marring if you want or grab a ton of little flat head screw drivers. Start at one side and start releasing the "one time snap" from the back. There is NO metal part - it is all PC/ABS plastic blend - so be a little careful!
Once you have a few opened - and if you run out of screw drivers...What I did for the Grille and what I do for the switch row electronics is to cut a small piece of styrene, card stock or what ever you have into strips that will fit into the slot - replace the tool with a holder that allows you to slide out the part!
Good luck,
Jake
Old Aug 1, 2008 | 09:15 PM
kiamcoj's Avatar
2012 CLS63
Thanks for all the help guys! Got them off!
