12V Power Outlet Problem
Old Aug 2, 2008 | 04:31 PM
butler's Avatar
2005 C230K
My 2005 230K rear 12V Power Outlet has no power?? Checked the connections on the back of the outlet, checked the fuse (#12 rear trunk), both ok. Noticed when I placed the circuit probe on the #12 fuse connection it has no power (both with Key in #1 & #2 position). Is there another fuse? Any one have any ideas? Thanks
Old Aug 4, 2008 | 03:47 AM
magnus203's Avatar
CL203, W211
My advice to you is check ALL the fuses. Might sound a little crazy but in the past I have come across similar problems on vehicles, the fuse is ok but another fuse on a completely different row is dead and when replaced, voila, all is fixed and well. Even though the vehicles fuse map says the actual fuse for that component is completely different.
Just a suggestion from experience, worth a shot
Old Aug 4, 2008 | 06:17 PM
butler's Avatar
2005 C230K
Thumbs up
Thanks, it does sound crazy but the way these cars are built you never know
Old Aug 5, 2008 | 04:01 PM
ChrisBrown's Avatar
2005 C240 4MATIC, 2020 GLC300 4MATIC
Yea, I concur. If you have a spare for that fuse slot, it wouldn't hurt just replacing it anyways, just to be safe.
Old Aug 5, 2008 | 07:24 PM
butler's Avatar
2005 C230K
Thanks for the input, I look at every fuse and replaced #12 with no luck. I have to go to the dealership anyways as today the sunroof switch stop working properly as the auto open no longer works. I have a few months remaining on the warranty and will make good use of it. Thanks again
