Anyone knows how to replace a brake light?
Old Sep 15, 2008 | 02:18 PM
maccooper79's Avatar
Black 02' C230
I got this 2002 C230 and in the manual it eems so easy to replace the brake light until I actually got to the darn thing...it won't budge and there is no levers to pull on like it says in the manual.
Old Sep 15, 2008 | 05:22 PM
RA71325's Avatar
There should be two spring clips on the sides of the lamp module and one on the bottom. Spread the two on the side and tilt out the module. Swap the lamp; it is a twist-lock. Reseat the module on the bottom clip and snap back into position. Finally, make sure the cable connectors are seated firmly in case you dislodged them in handling the module.
Kal
