ESP Control Module Failure
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jun 12, 2009 | 12:41 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by LILBENZ230
So if it were a wheel speed sensor, wouldn't that cause the ABS system to also not work (thus giving you an ABS light?).
The ABS uses the wheel sensors. I can see how ESP module, steering angle system, and yaw sensor doesn't cause ABS to shut down but a speed sensor?
Yes.
Old Jun 12, 2009 | 12:52 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i had a smiliar problem on my c32. someone told me it could be the throttle actuator or the throttle actuator harness. I spent $50 on the harness and some one told me you can fix it with a zip tie. I took at look at the harness and found out the plastic tabs that hold the harness together broke. I zip tied it shut and i didnt have problems with the esp module going out anymore.
I basically fixed the problem for 10cents. I'm keeping the harness for a rainy day and eventually will replace it. Not sure if it applies to the regular w203's since it doesn't have the super charger. I know there was a tsb for that same harness for the c55's though.
Anyways, just wanted to share my experience.
Old Jun 12, 2009 | 02:13 PM
aznmode's Avatar
2010 c300
Originally Posted by mleskovar
I'm assuming you put 4 new wheels/tires on? The sensor is at the end of the wire. It's the only wire going to the wheel, you can't miss it.
Thank you. I checked all 4 and no broken wire or disconnection. It's at the dealers now for alignment. I'm hoping it's because of the alignment. If it's because of the different wheel size, I'm not sure how I can fix that. I'll post update in a few hours.
Old Jun 12, 2009 | 03:47 PM
PA_Pete's Avatar
2001 C320
Good to know! Could you do me a huge favor and take a picture of said harness? I just had a problem with my C320 where the independent shop told me that the Throttle Actuator, or Throttle body was bad. I already ordered a new one and it actually arrived today, but I was wondering if the problem was with the throttle body itself, but with the wiring harness that plugs into the throttle body. I only ask for a picture to see what it is you are referring to and to see if I have the same set up on my N/A M112. Thanks!
Old Jun 12, 2009 | 07:11 PM
aznmode's Avatar
2010 c300
Ok so my SA called me today and told me the ESP warning went on cause my car was way out of alignment. After alignment the ESP turned off. I think it might have been due to the pothole and new rims. I hope it stays off so I can finally enjoy my new shoes
Old Dec 3, 2009 | 09:34 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
My Uncle have a similiar problem with his 2002 w203, and I connected my DAS and it says that there is a fault stored on the yaw sensor, I deleted it just to confirm and it appeared again.
Any one knows if that is causing the problem of the ESP ligth ON and ESP actuating sometimes after 100Km/h while driving straigth!?
Or just could be a wheel sensor? but if it was shoudn't there be a fault stored for the faulty sensor?
Thanks for any help
Old Dec 27, 2009 | 06:56 PM
  #32
advans's Avatar
C55 ///AMG, 535xi
hmm, I took the easy way out gaiex, I just traded the car in, the dealer told me I needed a new ESP control module so I said "f this"
Old Nov 17, 2010 | 03:48 AM
  #33
sirei808's Avatar
c200 Kompressor
more on ESP
Hi Guys,
I drove today on the Express way and during sudden braking, I could feel something holding back (like my brakes locking) then ESP Light comes on.
I noticed this everytime I come off a fast run then have to slow down and apply the brakes.
Has anybody experienced this?
BTW, I drive a W203 2001 C200 Kompressor.
Yaw Sensor has been replaced last 12 months.
Running on Size 235x40xR18 Wheels.
Need your valuable inputs, please.
Many Thanks
Old Aug 2, 2013 | 09:13 AM
  #34
JUNEBLOOD's Avatar
00 cl500 turbo 03 e500turbo w203_63 w203 m271sc/turbo
Originally Posted by pshek
Your ESP module might be going bad because of oil contamination or oxidative corrosion at the electrical connections. It probably does need replacement. I've heard of other people who had ESP modules going bad because of bad electical connections from contamination or corrosion.
The fact that your car fishtails alot is nothing unusual since your traction control does not work right now. Mine did that too because I permanently have ESP/BAS disabled. Good tires and LSD helps keep the car from fishtailing now.
Don't drive your coupe in the snow or the rain right now til you get it fixed.
I know this is not what y'all talking bout but I have a c32 motor 4sale
Old Jun 3, 2016 | 02:52 PM
  #35
imedina's Avatar
Mercedes Benz C 180 Kompressor
Unhappy ESP error report
Could you please explain how do I perform de LOCK TO LOCK procedure. Thanks
Old Jun 5, 2016 | 08:04 AM
  #36
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Turn the steering wheel all the way from one side to the other 5x in a row.
Old Jun 6, 2016 | 09:50 AM
  #37
imedina's Avatar
Thanks LILBENZ230. I am trying to to this (key position just before ignition), but it is really hard. Am I doing it correctly?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
