Paging BrabusCClass - Help with HID light
1 to 12V+ on battery
1 to Ground
1 to 12V+ off the original light plug
1 to Ground off the original light plug
That all went into a relay which in turn hooked up to the ballast which of course fed the lamps.
I cut the relays out and went direct - but that should give you enough idea on how to bypass the system and do it without going direct.
Peet
