Windshield wipers work like S@$t!
Old Nov 21, 2008 | 11:07 AM
MBCClassboy's Avatar
2007 C280 4matic/2001 Dinan Z3/2007 Z4M Coupe
'07 C280 4matic. Bought it in April and just drove it in my first snow storm. The car works great in the snow but unfortunately I can't see out the front window. It is like the blades won't conform to the glass and leave a big durty spot in my line of vision. They worked great in the rain above freezing but not now at 25 degrees. Ok, so maybe frozen? NOT! Twisted, bent and wiped then and no different. Maybe old, so I replaced them with new OEM. Work better? NOT! 10% improvement.
Both driver and passenger side leave untouched glass and I wind up laying on the center arm rest to see.
Am I alone here or have any of you solved this problem? Aftermarket????
Thanks, Greg
Old Nov 21, 2008 | 06:30 PM
jogger's Avatar
02 S500
i've had that before in several cars and what i do is to lift the arm and let it fall against the windshield and then they work fine
Old Nov 21, 2008 | 06:47 PM
Bin there, done that. Like I said I twisted, bent, wiped, and banged. It's wierd.
Old Nov 21, 2008 | 08:22 PM
shivi1345's Avatar
MK IV .:R32
ya the OEM ones suck
I put on Rain-X
Old Nov 21, 2008 | 08:33 PM
JLD2k3's Avatar
2002 C320
I put on Rain-X
I've had good luck with Bosch ICON.
Old Nov 21, 2008 | 09:39 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
just don't get anco they work very well new after a few weeks of long use they squeak and no matter if you clean them or not they will squeak and streak... horrible i only got them b/c it was what was avalible at the time
gonna switch back to BOSCH and get a set at autozone...
ive always used that rain X windshield washer fluid you know the orange one.. great stuff melts ice too
Old Nov 21, 2008 | 10:48 PM
Kompressive's Avatar
2006 CLK350 Cabriolet Previous: W203,W202,W201, 2 Porsche 914s, 1965 Jaguar XKE Roadster
I agree. The Rain-X fluid is great.
Also, I just put a new set of OEM blades on about 2 weeks ago, and they lift off of the windshield for the last 8 inches of the swipe on the left side. They were expensive, but I'm ditching them. With winter coming to Chicago, I need wipers that wipe. I'm going to try a set of Bosch tomorrow.
