How to set the time / clock [Need Help]
W203 CDI 2002
Hello,
I’ve got a C220 CDI from 2001 (w203) that does not have an option to set the time.
When I enter SETTINGS ->INSTRUMENT CLUSTER the is no SET TIME or TIME DISPLAY.
Only the option to choose AM or PM .
Also there is no CONVENIENCE or RESET menu.
What could be causing this ?
Any tips ?
Any tips ?
1 Post
2005 Mercedes C230 Sport Sedan (W203)
I had the option in my instrument cluster until I installed comand and programmed my cluster to see it, now the time synchs through GPS and I have the option to adjust my time zone on the comand.
If you don't have comand, maybe your car had one previously that was removed before you bought it (assuming you're not the original owner).
A bit of a disclaimer though, mine is a 2005, so I'm not sure exactly what will happen for the 2001-2004 crowd as the comand unit and cluster are both different than the 2005-2007's.
