Headlamp Washer Pump Location?
Old Jan 5, 2009 | 09:26 PM
PeterTheFish's Avatar
02 C32 AMG
So my Headlamp Washers have never worked properly since I've owned this car (02 C32) - I do understand that this may be somewhat desirable, but I can't stand having anything not working on my car!!!
I'm assuming it's the pump - I read that unplugging the pump is somewhat common, and there is no voltage drop / motor noise / relay click when I press the button (with lights and car on) Can someone post a picture or otherwise direct me to the pump and plug so I can move ahead? Part number would be good too.
Thanks!!!
Old Jan 5, 2009 | 10:33 PM
WaveyKat's Avatar
Something Slow
the pump is located on the Windshield washer Bottle next to the Drive side Foglight!
Old Jan 5, 2009 | 10:52 PM
02 C32 AMG
Hey -
Thanks so much for the quick response to my first ever question!!! Is this accessible from the top side, or do I need to get on stands?
Old Jan 6, 2009 | 08:18 AM
WaveyKat's Avatar
Something Slow
you dont need Stands but if you want more room to work you may want to remove the Driver side Front Wheel then Remove the Splash Guard and you will be able to see it!
Old Jan 6, 2009 | 04:16 PM
II6's Avatar
II6
W203 SUPERCHARGED
Has somebody the partnumber of the pump?
Old Jan 6, 2009 | 04:20 PM
02 C32 AMG
That one I can answer! 210 869 08 21 - from Das Russian Site
