How Accurate is your Tachometer?
Admin Alumni
I floored my C320 on the entrance ramp to a freeway recently. The auto kicked down correctly and the car took off. The second to third gear shift was interesting... The tachometer says redline at 6000 rpm, but the transmission shifted at about 6200. Whoa!
No complaints from the car, but MB-BOB sweated that last 200 rpm (.2 secs) wondering when it was going to shift. I'm wondering if the tach is that accurate at max revs. Any ideas? Opinions? Observations?
I think the true redline (per manual) is 6200rpm.. at least that's what I remember for my C240..
Many moons ago we also wondered if the TouchShift was set to 1, would it upshift automatically at redline or would it hit a revlimiter? Nobody has been brave enough to try yet (and I am NOT volunteering!! :p)
Re: How Accurate is your Tachometer?
i wouldnt worry about it. that engine will spin another 1000 rpm most likely b4 any damage starts to occur. dont worry the computer will not let it reach that stage. the engineers would not design a redline so close to the actual breaking point of an engine.
Admin Alumni
And no, I'm not volunteering, either. LOL!
Mine will not kick in the rev limiter until 6200 RPM and the specs state 6200 RPM redline but my tach is red after 6000 so the tach looks to be just marked that way. Maybe for safety sake to make people shift lower with the standard. But mine seems fine and the rev limiter does kick in at the redline the specs state. Just the tach is marked lower. I was wondering that same thing an hour ago.
Admin Alumni
2010 C300 4matic
I think your assessment is right on the money, mctwin2kman. (MB-BOB breathing easier).
If you put the transmission in "1", it will shifft at redline in every gear.
This is obviously most useful from a start, but if you are goofy enough to shift into "1" at speed (which I have NOT done - I did previously drive a manual, after all, and some things just aren't done!) it will not blow anything up. Supposedly.
In fact I am not sure how you can ever hit the rev limiter with an MB auto transmssion. The trannie is just TOO SMART.
2010 C300 4matic
My car shifts at 6200 also.
I have also tried this by putting the shift in 1 from a stop and not shifting. The car shifts automatically at 6200.
If you pull the shift (downshift) and hold it there while you are driving, it will only shift down to the lowest possible gear for the speed of the car/engine. I use this on the highway all of the time to pass (when I want to have fun). I don't think it's possible to shift down to 1st if your traveling too fast.
C240/6 Megma Red
I did hit the Rev-limiter more than once when I just have a car. I use to have a Turbo car which has a longer gear and the tranny on my C240 are so short compare to my old car.
1 Post
2002 C230 Coupe(M111)
The stock valve springs are designed to float before the engine can wind to an RPM were it would suffer catastrophic damage...and the ECU would shut off the fuel or go into full retard long before then anyway.
Beat the snot out of it I say!
I do seem to recall previous transmissions (for instance our ML tranny) are not so smart - it WILL allow you to shift down too far.
Don't really want to try it, though.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
MBworld Guru
white and whiter
1 Post
Originally posted by viper
Oh sure. Lets try it on your car just to check.
The redlines are far from where the damage occurs. A little beyond won't hurt. A motor accellerating under load is stronger than a motor reving in neutral - with no load on it..that can do some damage. The real damage occurs when you down shift from say 5th to 2nd, and wind 10K up on the motor...that will destroy stuff in a hurry.
Originally posted by FrankW
the speedshift will not allow you to downshift if the rpm and speed is too high for the gear. I've already tried it on the freeway. It will only downshift to the lowest "possible" gear.
Originally posted by Outland The stock valve springs are designed to float before the engine can wind to an RPM were it would suffer catastrophic damage...and the ECU would shut off the fuel or go into full retard long before then anyway.
A Bad Thing.
