Amp power wire question
Old Jan 28, 2009 | 09:19 PM
Benzo0573's Avatar
2007 C230 Sport
I was wondering how some of you ran your power wire from under the hood to the trunk, i plan on doing an install this weekend, but im not sure, first where to get through the firewall, ( im assuming somewhere under the driver side), then getting it into the trunk, i have a 07 c230, the back seats do not fold down, is there a trick or an easy way to get it into the trunk without issues?
Old Jan 28, 2009 | 09:47 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
there's a set of holes by the battery where you can run the wires though. A few of the oem wires are already running through. if you take out the lower panel on the passenager side you can see the holes for the firewall.
if you take out the door sill...there's a little funnel area where you can run the wiring..its the same place where the oem wiring is being run through.
Old Jan 28, 2009 | 09:55 PM
BlackC280's Avatar
C280
are you replacing your head unit as well? If so what unit did you choose?
Benzo0573's Avatar
2007 C230 Sport
wow, very detailed thanks so much, 1 more quick question for you, what about getting into the trunk? how did u get by the seats??
Benzo0573's Avatar
2007 C230 Sport
yep, i got the pioneer primer AVIC-F90BT
Old Jan 28, 2009 | 09:56 PM
BlackC280's Avatar
C280
do you have an answer to the back seat question? how to run the wires into the truck? i'm interested as well.
Old Jan 28, 2009 | 10:02 PM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
There's a fuse block in the trunk - and at least one switched circuit available (empty) - check your owners manual for details and uses a fuse tap to get a hot lead, then ground to any bare metal (there are several sheet metal screws back there)
Old Jan 28, 2009 | 10:06 PM
Benzo0573's Avatar
2007 C230 Sport
wait so your saying i dont have to run a power line from the battery to the trunk?? any idea where this hot lead is at, would it require me just connecting a 4 gauge wire to it, or is it more complicated
Old Jan 28, 2009 | 10:10 PM
Benzo0573's Avatar
2007 C230 Sport
i still would like to know how you got through the rear seats tho TemjinX2
Old Jan 28, 2009 | 10:30 PM
BlackC280's Avatar
C280
Will you be loosing your steering wheel controls with this install??
TemjinX2's Avatar
you can take out the rear passenager pillar seat. its the seat thats on the passenager side thats in between the top seat that folds and the door. you also have to take out the bottom seat. Behind the pillar seat is a hole in the chassis where you can run your wiring.
rick is talking about the rear sam. The rear sam isn't good for running 4 gauge wire, its good if you need a accel or remote wire for your amp.
Old Jan 29, 2009 | 12:39 AM
BigBodyBenzC240's Avatar
...a panty dropper...
When I had my system installed they had to take out the rear seats since they didnt fold down and there all one piece.
Old Jan 29, 2009 | 08:21 AM
bumpnzx3's Avatar
W203 C230SS
i took my seats out also- made running all of my patch cables and power wire easier. made the sound deadening process a little easier also. i had the seats out in under an hour- it wasn't that too hard. i wouldn't hook into the sram, in my opinion it's not meant to carry that kind of load.
Old Jan 29, 2009 | 09:12 AM
Benzo0573's Avatar
2007 C230 Sport
I don't even know how I would begin to take out the seats, any tips?
Old Jan 29, 2009 | 10:17 AM
PA_Pete's Avatar
2001 C320
It's not too bad at all. Of course, I don't have my car with me today, but from memory... (Sorry if this is different than your set up, my car is a 2001). You should see 4 plastic covers in the rear foot wells under the front end of the seat, the bottom portion of the seat. The pop off using a little flat head screwdriver. You should see a tiny hole in which to put the flathead in, once you do that, you press up slightly to pop off the cover. Under the cover is a nut, I can't recall what size it is, it's been a while since I removed my rear seat, but I want to say 13mm. Remove all four of those and you have the bottom seat out. As for the back portion of the seat, I have no idea, I never removed that. Sorry.
Old Jan 29, 2009 | 10:41 AM
Benzo0573's Avatar
2007 C230 Sport
im not installing the adapter to make the controls work, i dont really care i never used em anyways, plus the part u need to get is almost 200 bucks and comes from Portugal, id rather not wait a month to get it haha
Old Jan 29, 2009 | 07:31 PM
Benzo0573's Avatar
2007 C230 Sport
can you get into a little more detail about removing the rear seats, im not sure where to start?
Old Jan 30, 2009 | 06:09 AM
bumpnzx3's Avatar
W203 C230SS
pm replied.
after you get the seat out- there are several holes to run your wires through to the trunk.
