W203 sedan Fog lights
2003 C320
YES when I set my lights to auto and it gets dark out my fog lights don't come on unless I turn the knob to select them. Has anyone modified it so they come on when it's set to auto?
2002 C230 Coupe Black/Charcoal C5 C7 Auto
yes actually its an MB computer hidden function to enable this. turn ignition to position one, turn light knob to off, Just press up, up, down, down, phone pickup, hang up, pickup, hangup, hold menu front while turn knob to auto and hold for 3 sec....a chime will play indicating the cheat worked...now you should have 99 lives............................................. .......................................wait a sec.............................this isnt contra just turn the knob on and pull back for fog....dont be lazy. the car is already automated enough.
2002 C240 6-spd (ret)
Originally posted by MarkL
You can't pull the knob out for the fogs when in the "auto" position. You have to move it to either parking or low beam position.
W203
dunno how old the folks around here are but there was an old Konami Games cheat in the arcades for games like Contra, Simpons, Ninja Turtles, etc (up, up, down, down, left, right, left, right, A, B, A, B then START to get extra lives ).
2002 C320 Sedan
Hey TBERRY
THats not the correct code. It's UP, UP , DOWN , DOWN , LEFT , RIGHT , LEFT , RIGHT , B , A , B , A , SELECT START.
Stock 02' C320
With 6-Disc DVD/CD CHANGER( No Screen )
Stock 02' C320
MBworld Guru
white and whiter
Guest
Posts: n/a
i know mark thats what i said....u have to have the knob to 'on' position (which i assume any mb c class owner will know meaning manual on(low or city)....not auto....there is no "on" written on the knob of course. and if u didnt catch it previous post was what we call sarcasm....
Lerts say I want to leave the lights in "CITY" (or whtever you call the one that enables the high beams, switch all the way right) all the time with the switch pulled out to enable the fogs... can I walk away from the car and the lights will automatically turn off after a pre-programmed time?
I tried this and they never turned off (or at least not in the few minutes I went inside) which surprised me, I thought for sure MB would have a fail-safe against draining the battery...
Originally posted by taylor192
Can you answer this without sarcasm...
regardless shouldnt there be a mode where the battery will shutdown when the lowest minimal to start has been reached. Enough to still give you one good crank.
2010 C300 4matic
2002 C230K Sports Coupe
Originally posted by Matt230K
Yeah, it should have this, but I don't think it does. I think the radio does this, but not the lights. I have seen them go completely dead many times before from leaving the lights on. So I don't think they have any fail-safe.
Originally posted by jay
...and if I'm not mistaken, leaving the lights in the "on" position after taking out your key, will result in that horribly annoying "beep...beep...beep...beep"
MBworld Guru
white and whiter
btw don't know if this is also true for non xenon/bi-xenon. If i leave my headlight "on" when I took out the key, the xenon low beam will shut off only leaving the city and fog lights on. don't know if that's suppose to be a fail safe when you forgot to turn the headlight off or what.
Originally posted by FrankW
yep...
yep...
yep...
yep...
2010 C300 4matic
Yeah, but ever notice how many people don't even seem to hear the warning, not MB, all cars? It's amazing .
MBworld Guru
white and whiter
doesnt make much sense as xenon is supposed to consume less power then conventional halogen lights right?
btw BMW has the most annoying headlight "on" warning sound... but it does a better job at warning the driver though.
