Shorty shifter on their SS?
thanks,
Otherwise, there is nothing in the aftermarket. I do know that:
A) If you go with an aftermarket knob, it will PROBABLY sit lower, as the MB knob is pretty tall
B) You could cut the shaft to reduce the height that the knob sits at. Won't change the throws, obviously, and will increase the required effort to shift. Someone did a thread on it here a while ago, so if you're interested, do a search
I've got a Sparco Racing knob on my car (in smurf blue, of course) - the knob sits much lower than stock, so while I considered doing option B, it seemed overkill. Just remember that if you do go aftermarket, you'll probably have to deal with the boot not working properly, so if you're worried about cosmetics, it would be best to stick with Brabus, Carlsson, Renntech, etc.
my way around the shift boot, at least for my Focus was a razor blade and a black zip tie. i cut a small slit in the top of the boot, enough to get a tip tie in, pulled it up over the bottom of the knob, snaked the zip tie through, pulled it tight, and cut it off. the slit in the boot covered the connector just fine.
i would like to have a brabus knob- but i really can't justify that much money on such a small appearance mod. hell, it was hard enough for me to part with the cash for the CF lip.
cutting off the shifter and re-mounting another shift knob doesn't acheive this
there was a thread about this that the OG's might remember (if we're not too senile) - it was decided that the difference between the two shifters is like the difference between stirring pudding and stirring cement
Maverick, if that's what you really want, you're going to have to go custom. Mercedes sure ain't encouraging anyone to work on aftermarket support for their quickly-vanishing manual-equipped options.
But that would be probably the least stressful - seeing if a company already making them would look at yours to see if they could adapt it. But I wouldn't hold my breath. You're pretty much screwed.
