C230 Coupe Rear Camber Installation
I have installed a custom camber kit from SpeedyBenz. The idea is that if you lengthen the camber arms, it will decrease the negative camber caused by lowering springs. (sry crappy iphone pics)
However, when I lengthen the camber arms, the whole hub plate moves towards the front.
Before:
After:
It seems like that lengthening the camber arms will not only increase camber, but also make them toe in (which makes it move forward).
For the bolt near the hub, its hub-spacer-camber -3 spacers.
What would I need to change so that the hub won't move towards the front when I lengthen the camber arms? Thanks!!
I hope to post the steps after I figure out the problem, it will be my first diy post!
Before:
After:
