Positive camber after lowered springs
I got it checked and found that my front left wheel has a positive camber while the right has a nice negative camber... (the driver sits on the right so I never really get to see the left side of the car
hehehe )Anyways I got the spring taken out and put back in again, but still the same...I went to MB to see if I could get the camber bolts, they knew nothing of it but told me to get the part number... I got fustrated and filed the mount on the right shock inwards about 3mm... now it's slightly negative, but not as negative as the left side... there is no more leeway for further sanding... I guess now I'll have to sand the mount on the left shock OUTwards to increase the camber... hrmmm what hassles... first camber problem I've encountered... ever
By the way it's a C200K sedan with APEX springs specifically for this model, rear camber is fine... I wonder what went wrong.
oh yea, I have to ditch my 10mm spacers and lathe another... I seem to have gotten the inner hub diameter off by fractions of an inch... severe chassis shaking over 120KM/H.... comes and goes... I'm sure it's the rears cuz the steering wheel doesn't shake.
Also, I think filing out the center mounting hole was not a the right way to fix your problem. The first thing I would have tried would have been to swap the springs left and right to see if the problem follows the spring?
Having done several spring installs on W203s this year, I really can't see how you could have positive camber after putting in lowering springs
Well keeping in mind the fact that Thailand does not have a product liability law, even if the problem followed the spring I can't just return it or swap it... I'll either have to make do with back yard mods, or buy a whole new set.
