Brighter Reverse Lights?
Old Apr 2, 2009 | 08:43 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Just wondering if anyone knows of any good brighter alternatives for the stock P21W reverse lights. I can't see jack when it's dark and raining outside. Brightness is key, not looks. Also don't want any computer warnings, so no LEDs please.
Doing a google search, there's mention of size 796 bulbs. Has anyone had any experience with these?
There is also mention of 50W halogen reverse lights. A google search shows that many people melted their housings trying these, so these won't work.
Old Apr 2, 2009 | 05:58 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
have you checked piaa? they usually make higher wattage brighter bulbs. i dont think the sensors will go off if your using slightly more wattage.
Old Apr 2, 2009 | 06:32 PM
slammer111's Avatar
^ You are right. Lower wattages trigger the "bulb out". Higher wattage is okay but then one needs to worry about excess heat or burned housing.
The reviews for 3497 and 796 say they draw "marginally" more power, but give off much more light, ie improved lighting per watt. However they also take less than 40W each so the current draw isn't too crazy.
Old Apr 2, 2009 | 07:53 PM
TemjinX2's Avatar
i think reverse lights it should be fine with the excess wattage since there not used often or for long periods of time.
Old Apr 2, 2009 | 08:11 PM
Mu9enx's Avatar
01' C32o
polarG hyper whites. i have them and jonathonmax has em, and they are white/bright as hell. i see a lot, like hids in the rear. (okay, maybe not that bright,, lol)
