navigation question
Old Apr 4, 2009 | 01:17 PM
odessit's Avatar
2009 E350 Sport (gone) 2012 E350 (gone ) 2014 E63s ( gone ) 2016 E63S Diamond white 2019 E63s AMG
navigation question
i have recently installed factory navigation into my 2007 c230.
everything works fine except the time display. it shows the wrong time, and when i try to go to system to change it it simply dosent let me do that.
is there some sort of a trick to do this?
if anyone know plz help me out
thanks
Old Apr 5, 2009 | 01:30 AM
wongster's Avatar
09 ml350 4matic
do u have the gps antenna installed? i had the same problem too when i installed the stock command unit. the antenna didn't come in till later one. once i added the antenna the time didn't fix itself. i left it over nite n when i checked it in the morning it was fine. so i think the antenna will pick up the gps signal n time.
Old Apr 5, 2009 | 08:49 AM
odessit's Avatar
i have the gps antena connected, but the time it displays is 2 hours behind.
also when i go to the compass mode the setelite info is blank. did u use the factory mercedes antena?
Old Apr 6, 2009 | 06:39 PM
wongster's Avatar
09 ml350 4matic
can u actually enter a address and it will guide u there? i didn't go with the stock navigation because my command came out of a crashed c55. i used this antenna http://cgi.ebay.com/GPS-ANTENNA-For-...3286.m20.l1116
works like a charm
Old Apr 6, 2009 | 07:25 PM
BF_JC230's Avatar
2005 w203 C230
Hi,
Can you guys list your Part Numbers of the MCSII units you installed? I am looking to install a unit in my c230...I have an aftermarket antenna as well.
Please post any information you can! Was it all plug in play - did you have to have your LOOP programmed...that mybe part of your problem as well!
How hard was it to unplug / plug in the fiber optic cables?
Thanks,
Jake
(Please Search the forum...I have a few posts on this forum)
Old Apr 6, 2009 | 09:46 PM
wongster's Avatar
09 ml350 4matic
i don't no the part number but it was out of a 05 c55. its just plug n play. i have a friend at that works at the merc service n he reprogrammed my on screen dashboard display so i can see the directions on there. the only problem i have is that the voice guide is a little low but thats ok. the whole install took about maybe 20 minutes
Old Apr 6, 2009 | 10:59 PM
c230yvr's Avatar
Originally Posted by wongster
... its just plug n play ... the whole install took about maybe 20 minutes ...
Guys, im sick of hearing this posted on this forum time and time again. Read the threads, search the forums. You will find part numbers and all the info you need. Anyways its not always plug and play. It depends on your setup vs the previous owner's setup. You have about a 30% chance of installing your new comand and just getting a nice black screen and a whole lot of nothing, in which case you need programming.
Old Apr 7, 2009 | 12:00 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
To fix the low volume problem with the directions, just turn the volume knob up while the voice is talking. If the voice stopped, hit RPT to repeat the voice command, and then adjust the volume on the voice again.
