eisemann race exhaust install
Old Apr 8, 2009 | 12:27 AM
FFemt5287's Avatar
2005 C230K Sport Sedan, 2004 ML350
hey guys,
just bought a used eisemann race exhaust from kevblah and i'm picking it up friday. is this system able to be attached with a pipe clamp, or does it need to be welded? id imagine this would be a pain to weld onto the pipe while the exhaust was still on the car. i'm hoping i can get clamps for this.
brandon
Old Apr 8, 2009 | 02:41 AM
iJimpanzee's Avatar
2009 SLK 55 AMG
I recently bought one too from another member on this board, and yes: you can use clamps to mount it... but welding would be a better method from what I've been told.
Getting mine from UPS next Tuesday
Old Apr 8, 2009 | 06:17 PM
bumpnzx3's Avatar
W203 C230SS
Either/Or would work. I would go with the welding method. Any decent exhaust shop could do it for you. I would think it would cost around $50 at the most. Clamps would work also, but you will most likely need to get a pipe expander in order to make it a slip fit, with the clamp around that. Most of the chain stores (Autozone at least) has free loaner tools. This is an easy tool to use- slip it in the pipe, put your ratchet on one end and start cranking.
Old Apr 8, 2009 | 07:09 PM
FFemt5287's Avatar
thank you guys, i think i'm going to have it welded at your advice.
