Rims stuck on?
Old Apr 17, 2009 | 01:20 PM
krisv420's Avatar
02 C320 Sedan
Rims stuck on?
Hmm Well yesterday i was really board so.. I really wanted to clean my car i took of the left front wheel put my spare on. After i was done cleaning it i put the orig wheel back on. But when i was going to take off the other rims they seem stuck on really tight.. I tried the other three wheels front right, Rear left , Rear right, i took the bolts off but the wheel just will not pop off..
Any ideas? Hmm
Old Apr 17, 2009 | 01:40 PM
COR Forged's Avatar
Former Vendor of MBWorld
Manufacturer
Hope this helps:
You can spray some WD40 around the hub thru back of wheels then put you feet on the left and right side of tire..... wiggle away
There are other methods of forcing to take them off but sometime this is the best just to get it loose from hub. Then slowly take of with hands
Old Apr 17, 2009 | 01:42 PM
bumpnzx3's Avatar
W203 C230SS
kick the tire or hit it with a large hammer in a few different places. be careful not to let it drop off completely- you don't want to damage the face of the wheel.
Old Apr 17, 2009 | 02:29 PM
coin's Avatar
'06 CLK500
^^ Hit the tires with a hammer
Old Apr 17, 2009 | 02:37 PM
krisv420's Avatar
02 C320 Sedan
If i had rims like yours i wouldn't dare to hit them with anything lol
Old Apr 17, 2009 | 02:50 PM
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
Just kind of have to kick them a little to get them loose since they have probably been on there for a while.
Old Apr 17, 2009 | 10:21 PM
acr2001's Avatar
2012 C300 4Matic
Like everyone else said, either kick the tires until they get loose, or CAREFULLY (without putting yourself under the car) beat the hell out of them from behind with a rubber hammer. Never pull on the tire, you can knock the car off the jack.
Old Apr 17, 2009 | 10:40 PM
jogger's Avatar
02 S500
hit the tire with a rubber mallet
Old Apr 20, 2009 | 01:59 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
kick the tire
Old Apr 20, 2009 | 06:27 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i doubt stock wheel with tires will get damage when you drop'em.
Old Apr 20, 2009 | 10:43 AM
bumpnzx3's Avatar
W203 C230SS
i'm not sure if they would or not- but i have damaged the face of another wheel on another car when i was rolling it through the shop and it fell on it's face. since then- i have been careful of that, no matter what wheel it was or what car it was for. one of those things that was burned into my mind
Old Apr 20, 2009 | 10:44 AM
bumpnzx3's Avatar
W203 C230SS
tires- not the wheels.
Old Apr 20, 2009 | 10:52 AM
M-bENZ's Avatar
Corrolla
use the RUBBER one
Andy
Old Apr 20, 2009 | 12:17 PM
jmf003's Avatar
'03 SL55
Try using a little PBlaster on the joint between the wheel and hub. That might loosen things up and enable you to pull off the wheel.
Old Apr 20, 2009 | 09:26 PM
kirax2's Avatar
I drive a Toyota Hybrid...
hammer it +1
or STFF its been discuss hahahah
when your car was in the factory they put glue between your wheels and the hub, once you get it off or Aftermarket wheels, things are easy now not more punding
Old Apr 20, 2009 | 09:32 PM
RedG's Avatar
a g
Deadblow or rubber hammer, from the backside, on the wheel. Also screw one lug nut back on a few threads, that will prevent the wheel from falling freely off the car and risking damage to the face of the wheel.
Old Apr 21, 2009 | 02:13 AM
BlackC280's Avatar
C280
hahaha... had the same issue.. I sprayed the WD40 between the hub & wheel and put on the old skool steel toe boots and kicked the $#iT out the tires. Finaly fell of after several kicks.
Old Apr 21, 2009 | 03:29 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by kirax2
hammer it +1
were you eating glue when you typed the last part, jordan?
Old Apr 21, 2009 | 04:28 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Use your head...literally.
Old Apr 21, 2009 | 11:57 PM
krisv420's Avatar
02 C320 Sedan
Sounds good hahaha =D I got them guys thanks again
Now my question is i have two jack stands. Were do i put them in the back of the car? Better safe then sorry riteeeee
Old Apr 22, 2009 | 02:10 PM
Utahkompressor's Avatar
W124, W203, W204, W251
^lower control arm or the slot that OEM jack goes.
Old Apr 22, 2009 | 03:08 PM
rinosaur's Avatar
2019 E450 Sedan 4Matic
The problem I found with the control arm is that there is only one flat place on it and at that point, the metal comes into contact with the jack only at one tiny piece. Isn't this too much pressure for such a small area?
