amp
Old May 7, 2009 | 10:56 PM
rrocha's Avatar
c 320 wagon
amp
Hello again, I have a 02 c320 wagon with only the bass part of the amp works, Iremoved the amp and cleaned it up and still no sound, I think the amp is no good, my question is 1st can I get it repair? 2nd where or who has one for sale, my amp has a plug with 2 wires that lightup when plug into the amp, 3rd can it be replace with an after marketone. thanks for your help.
Old May 9, 2009 | 06:24 AM
drastic's Avatar
2002 c320 wagon
im by far not a benz guru like most of the folks here but i can tell you what i found on mine since i have the same wagon. it all works with fiberoptics for what i learned. your best and easiest bet is replace the amp. i believe you wont be able to use an aftermarket amp with the factory unit. thats why i ended up replacing both the head unit and amp and kept the bose speakers. make sure all your connections are in place. if all else fails, you can have mine for $50 plus shipping.
Old May 9, 2009 | 09:46 PM
rrocha's Avatar
c 320 wagon
Hi, where are you located , and how do I send you the money
