Stripped Oil Filter Cap's 27 mm plastic bolt
2005 c230K SS
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
So I managed to strip the 27 mm plastic bolt on top of my 05 c230 K SS 's oil filter cap. Has anyone done that and if so, what are my options?
Thanks.
Thanks.
Are you able to take it out? I stripped my Drain Plug once (different car) so I used a wrench instead of a socket to take it out then got a new drain plug. I'm sur eyou can get a new bolt from the dealer.
2005 c230K SS
I stripped it as I was putting it back in . I will take it off when I change the oil again.
Te "bolt is actually built into the top part of teh oil filter housing cap. I would need to get the whole cap.
2005 C230K Sport Sedan, 6 speed manual
I think your only option is to replace the plastic cap. This is probably a dealer special-order part. It shouldn't be terribly expensive. Whatever the price, it is cheaper than replacing your engine.
I would recommend replacing this sooner rather than later. Do not risk an oil leak, or having the entire plastic cap blow off while driving down the road.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2002 C230K, 2013 BMW 328, 2015 BMW X5
True! We have all cross threaded a bolt in our time. It happens. Insure you get any loose bits of plastic cleaned out.
