CD Changer - "Magazine Empty"
Old May 14, 2009 | 10:43 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Question CD Changer - "Magazine Empty"
Hi all,
Today I tried the 6 disc cd changer. I loaded up 6 CD's (all original, not CD-R's etc), but when I hit the CD button on the player, The display says "Magazine empty".
Has anyone come across this issue before? If so how do I fix it?
Worst case scenario, I may consider purchasing a newer MP3 capable CD player and connect it using the same connections to the system (if possible).
Any thoughts?
Old May 15, 2009 | 08:04 AM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
Search the board some, I remember seeing some threads on this.
I think what they ended up doing was remvoing all CD's and letting the changer run though (hit the CDC, and then hit numbers 1 through 6, letting the CDC try to play them). I don't know if it works right away or if it takes time, but they got it to work without replacing stuff.
Old May 15, 2009 | 01:21 PM
jcnash's Avatar
Thanks SickSpeedMonte.
Found the thread.
Old May 18, 2009 | 09:07 AM
No problem. Did you resolve the problem?
Old May 18, 2009 | 03:54 PM
jcnash's Avatar
Yep I did, but the procedure suggested in that thread didnt solve it.
I pulled out the changer, opened it up and had to release some gearwheels that were jammed (im guessing from non-use).
Works now, but Im not too satisfied with the fact that it doesnt play burnt discs.
Probably going to pull it out and sell it.
Old Apr 13, 2014 | 10:52 AM
rick62's Avatar
ML350
In another post on this subject a user reported that an MB service rep told him to go to the unit, hold the eject cartridge button down and tap the cartridge with a screwdriver handle. I did that to mine and ir corrected the problem!
