Young here are the Fuel and ignition settings
but wait ... there's more!
perhaps it's cheaper from IBM directly? I think the other company is reselling it.
Click Here:
Star Diagnosis System info on IBM
2002 C320
I also am interested in running the fuel settings in ECONOMY mode so that I can pump cheaper gas, saving over $1,000 over the next few years. (Although I own the C320, I'm a fairly "sedate" driver so performance is not a key consideration.)
What octane level can I burn in ECONOMY mode? Other than a degradation of performance are there any short or long term negative effects to the engine by running in economy mode?
Thanks!
Thanks!
Originally posted by renncpe
I lost about 2 mpg thats it and there is a change in performance.
I would think 5-7 hp for 15 min labor, it's not that bad.
Randy
Randy
I don't see how changing the fuel setting could increase horsepower unless it increased ignition timing. This would require the use of higher octane gasoline but in this case, the fuel economy would probably be BETTER!
ok, we discussed this in more detail in the tuning forum. see this thread --> https://mbworld.org/forums/showthrea...&threadid=6756
but generally, it seems that the fuel RON settings will allow you to use lower octane fuel. see the thread for the table that shows the RON converted to US Octane (eg 93RON = 89 US Octane) not sure what the long term effects would be by using these settings.
1 Post
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
fuel settings program
Is the fuel settings program the same as the ignition correction program, or are they 2 different areas of adjustment?
Former Vendor of MBWorld
Originally posted by Lynn
Rick, you should send that guy the sceen shots.
#32
ARRGH!!!
This gets me so furious- its not going to do anything illegal to the emissions. These settings are there to help tune driveability issues, all legal, all OK in MBZ's eyes. I mean, come on, they made the F***&^% machine right?
#33
1 Post
ignition- Kleemann
Kleemann- we checked my 2000 S class today, and it has the ignition correction program in it. It has Baseline, 93 RON, 91 and 89. Will it be of benefit to switch it to 93 RON from the Baseline?
Also, should the fuel setting, if it is another program, also be reset from baseline? Please let me know, as the ignition setting has alraedy been changed to 93, but can be changed back bfore it leaves the shop.
#35
Re: ignition- Kleemann
#37
Originally posted by C230 Sport Coup
What "stage" are they set for from the factory?
