2007 C230 iPod Question
Old Jun 12, 2009 | 05:09 PM
c230inorlando's Avatar
c230 sport
What's up guys...
i know there are a couple threads on this but haven't found the answer to my problem yet..
i've to a 2007 c230 sport. Just bought it used. Previous owner had the cd changer removed and replaced with an iPod adapter (kit). However i can't get my iPod to work. Plug in the iPod and the mercedes logo shows up on the screen, but i can't control it (on the iPod) and can't get the sound system to switch over.. how do i get the system to go to it? how do i get it to work?
any suggestions will be appreciated!
Old Jun 12, 2009 | 05:40 PM
LewFX's Avatar
2009 MB C300 Sport
is it on aux ?
fitzgeraldo88's Avatar
SLK 55 - 2013
wrong forum
tHIS IS A W204 FORUM.
BUT YOU NEED TO PUT THE RADIO EITHER ON CD OR AUX.
IF NOT, JUST GET A NEW CABLE.
Old Jun 12, 2009 | 05:50 PM
c230 sport
it's embarrassing, but i know very little to nothing... i would imagine it was installed on AUX.. previous owner paid the $600 to have the dealer install.. the connector is in the glove compartment.. if i do 'CDO' it goes to the CD.. if i do CDC it's says "no CDC".. how do i go to AUX?
Old Jun 12, 2009 | 07:39 PM
aranu's Avatar
C230 2009 , E320 1996, C230 Coupe 2002
You have a W204 right? If so then in disc mode, use your thingamajig near your armrest and pull the dial down, then scroll over to the left and press down on the dial, and aux should come up as a option to choose from.
Old Jun 12, 2009 | 08:55 PM
nepodevil's Avatar
06 C230 SS
If I am not mistaken you hit cdc a few times ina row and it will give you the aux..
Old Jun 12, 2009 | 10:29 PM
W203E35's Avatar
2006 C350 Sport 6MT
You have to hold CDC.
Have you tried holding it?
A mercedes screen? So you have the command? (navigation)?
Old Jun 12, 2009 | 10:30 PM
W203E35's Avatar
2006 C350 Sport 6MT
IF you press CDC that will activate the CD Changer but since there is no CD Changer it is jumping back,
BUT
If you HOLD CDC than that will activate the AUX.
Man 600 bucks????????? What a ripoff. It's so easy to install the AUX.
Old Jun 13, 2009 | 01:30 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
idk why he removed the changer...i had bestbuy install man for 60 bucks (stealer wanted 300) and my changer still works...all you have to do to get it to work is hold down cdc until the ipod thing shows up...you also can't control from the ipod but from the steering wheel or h/u...gl
Old Jun 13, 2009 | 02:37 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
You can control the iPod from the HU... do you have to have command for that? I know in the 2008 S class you can only control from the steering wheel.
Old Jun 15, 2009 | 11:52 AM
c230 sport
thanks guys for all the input.
holding down CDC for a bit (3 seconds), puts it into AUX mode.
Appreciate all the advice!
Old Jun 15, 2009 | 01:09 PM
maverik259's Avatar
yes w/o command you can only control it from the steering wheel...w/ command it shows up on the command screen as well...
and no problem glad to help
Old Jun 15, 2009 | 01:20 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
I assume this is a different kit than the 3.5mm mini jack cable that you install under the passenger side door sill plate and route to the side of the glove box? I've never heard of being able to control a device through a mini jack.
