3rd (Center) Brake Light
1 Post
'05 C230K SS
I searched on this and didn't really find anything. I've gotten a "malfunction" indicator for my 3rd brake light. Has anyone ever replaced theirs before? I assume you'd have to take the panel off the trunk lid and come in from behind. Does MB break it down into different parts? Or am I going to have to order an entirely new brake light assembly and replaced the whole thing? Any help/advice is appreciated.
1 Post
'05 C230K SS
Not from the outside. You have to take off the trunk liner and install it through the inside. There was another thread on this about a month or so ago where I described the process. Not very complicated...just takes some time to pull all those pins/grommets out.
Something Slow
found this https://mbworld.org/forums/c-class-w...e-light-2.html
it may help others in the future
To install: the brass clips must be attached to the Light then you insert the light be carefull how you push the light BREAKS easy!
